Yes, there it is, but what I'm asking for is the ability to add it into a button on the skin for quick access.
What is your scenario? Please, can you explain it in more details?
Ok, thanks. I will add an option to context menu of play button in next version. Just for now, you can use hotkey for "crossfade: on / off" action
Thanks for considering my request. By the way, I don't know what you mean with "...you can use hotkey for...", which hotkey?.
Which you specify. Refer to app settings / player / hotkeys. Now, search the "crossfade" command
