Peak normalization doesn't work in realtime if Replay Gain tags are present
Topic: Peak normalization doesn't work in realtime if Replay Gain tags are present (Read 1786 times)
June 27, 2025, 14:33:16 »
Arkon77
Peak normalization doesn't work in realtime if Replay Gain normalization tags are present ( file or album )
Re: Peak normalization doesn't work in realtime if Replay Gain tags are present
June 27, 2025, 15:24:35 »
Карма: +3150/-75
Yes, this is correct behavior. Normalization will use already calculated peak value for more accurate normalization.
