File: http://localhost:8000/radioCode: 2 (00000002)Message: Can't open the file-------------------------HTTP/1.0 404 File Not FoundServer: Icecast 2.4.4Connection: CloseDate: Wed, 03 Jul 2024 12:50:15 GMTContent-Type: text/html; charset=utf-8Cache-Control: no-cache, no-storeExpires: Mon, 26 Jul 1997 05:00:00 GMTPragma: no-cacheAccess-Control-Allow-Origin: *
About Internet Radio, I would like to have an option to force an unlimited attempts when the connection is lost, AND even if the stream url doesn't exist at
Hello Artem,Thanks for your reply.I use AIMP on a server playing 24/24, and I would like it restarts, even if the connection is lost after 2 days. The maximum possible value is 1000, which means, with a break of 5 seconds between attempts, the player will have stopped in less than 2 hours.By the way, on the 32 bit version, it seems this feature is not working at all : this message popup after the 1st failed attempt.
Will it be implemented in the next stable release?
