how do i actually 'refresh'/rescan a PL?
because i can find nothing that says 'Delete' or 'Delete PL'.
that is all i can remember atm :-)
Only smart-playlists can be refreshed (rescaned). For usual playlists, only tags rescanning is possible. To create a smart-playlist based on music library, click the right mouse button in grouping tree's node and select "Create smart-playlist". Next, you will able to "reload data from the preimage" in misc. menu of playlist pance.Click on the "Remove selected from disk". If you want just close the playlist tab - just uncheck it mark.1) how to reproduce that? can you explain your actions via step-by-step instruction?2) because playlist's location is empty (I think, playlist was not yet saved by app)
remove selected from disk appears to be under Manage PL, not on RMC (right mouse click)
Hover over the three dots and a popup will appear.
but how does anyone know that is the "Misc Menu" in doco?
