Yes you can un-dock the Playlist window and move it around anywhere/resize it as you like. Go into the AIMP/Profile/Skins folder. open the *.ini file of the skin you use in a text editor and go to the [PlaylistFrame] section; then change the value "Docked=1" to "Docked=0".
You can undock the playlist window just by dragging it away from the main window, no need to edit the .ini file.Anyways, that's not what he wants. He is talking about the playlist list, i.e. tabs.
