1. How you do "jump back"?2. What reason to duplicate each song in user's queue? User's queue provides an ability to override standard playback order that provides by playing playlist. 3. What reason for? Equalizer must be adjusted once for your hardware.4. This feature is already in AIMP. Whats is multi queue? We have no plans to implement an ability to display playlist content in widgets in near future.5. ;-)
Than next day when I play until the end of playlist which I partially played before, its only play songs which unplayed before not all of songs in playlist.
EQ shortcut for EQ sets and presets: different file quality
and output eg. to headphones A, B, active speaker A, hifi set B sometime takes different preset to fit our ears & sometime we need a little adjustments in here or there.
More channel: when use limited equipment (old device, low-end headphones or low-end hifi set) I always cut even cut-off around 60Hz for prevent annoying sounds. I think if there are more channel for low and high will give more options to get good sounds, remind me if Im wrong.
I meant in playlist we can select more than 1 song, than we can add to queue or send to another playlist or else, not 1 by 1.
Multi queue (like Musicolet) : we can create more than 1 queue, so we can combine many songs from different existing playlists eg. to queue Sunday, Monday & so on, no necessary to creating new playlist again. So we can creating playlist only for indexing songs.
file quality cannot be improved via equalizer.Why annoying sound must be in this case? Down-mixing is not downsampling without filter, I have no idea why sound may distort here.
We provides playlists for that.
