1.01:- Fixed: radio button wouldn't dissapear when in Stopped state in File Info large size.1.02:- Added Tabs width options for Vertical Tabs. 1.03:- Fixed Visual Display menus. Right-click always opens "Mode/Visualization/Skins" now.1.04:- Adjusted "Tabs width - medium" size so that it is balanced between original size and large size.- Made "Tabs width" to reflect better if they are available or not. Shortly: they are very dark if Vertical Tabs is not enabled.1.1:- Added Equalizer as an option to Simple mode. You can chose between File Info and Equalizer in Design Options. Note: they are disabled if you have disabled Complex/Simple switch.- Changed Radio capture icon. Hopefuly better.- Adjusted: File Info can't be changed if it's disabled.- Adjusted: Preset button from EQ can be right-clicked to acces DSP Manager quickly.1.11:- Fixed: radio button wouldn't dissapear when in Stopped state in File Info large size. Again.1.12:- !! Embedded SegoeUI fonts in the skin so that everyone will get the exactly same look. Before, having your SegoeUI font modified would make the skin different. That's the reason why the skin is over 1mb size now.- Fixed: Shading option 4 for Tray-Control. Should look better.- Adjusted other minor things.1.13:- Added an option to disable or enable Title indenting. Not everyone likes indenting.- Fixed other minor things.1.14:- Fixed the problems caused by the update to AIMP 3.50 RC2 build 1270.1.15:- Fixed another issue from Aimp3.50 RC2 update.1.2 (Final):- Nothing modified. Compiled with the final version of Skin Editor 3.50 so that I can sleep well without thinking of this as a Beta anymore.- This is pretty much the last update it will get unless I find critical issues.
You can enable Design options by pressing the Gear icon (top left corner of main window). There you have most of options.
Можно ли добавить обложку дистрибутив плеера?
Сомневаюсь, что будут добавлять. А надо ли вообще?
Возможно ширину плей листа увеличить?
I'm very impressed. You did a very serious work and really showed a new high level in the skinmaking (and flipped my thinking about the approach in the creation of the skins). And inspired me, and I think the others, to create a more beautiful creations. Really good job.P.S. I apologize for my bad English.P.P.S. (For Russian community) Я действительно впечатлён. До этого момента я даже и не знал, что Skin Editor позволяет сделать ТАКОЕ... К сожалению, с ним я начал разбираться только после того, как дизайн обложки уже был готов Думаю, теперь новое поколение обложек будет все более гибче и гибче, ну а также юзабильнее и красивее...
Не правильно выразился, не плей листа, а ширину списка плей листов. Чтобы больше информации помещалось по ширине, примерно на одну четвертую.
[en] Error: Invalid skin formatversion 3.50 beta 4
Please, fix a Visual Display: add only one link (DisplayValue <-> DisplayValue) and select popupMenu "pmDisplay" in properties.
I'm afraid you'll have to clarify a bit. That link and popupMenu are already set. What's wrong?
What you said is already done except I also have another link:"Visual Display (Action -> CoverArt) prvPlayingFileInfo" to be able to open CoverArt in original size in Windows Photo viewer.That was done so that people can open CoverArt as well as enable Visual Display by right-clicking it.
Tried to fix this. It should work normally now, CoverArt available or not.
To moderators: what do I do if my skin file is over 1mb size? It's over the forum's limit and can't upload it anymore. =/
Updated to 1.13. Like before, the file is on DeviantArt website.I added an option to make Title same length as Artist.
кто то мне объяснит что за изменение в версии 1.13,а то я его не земетил
1.13:- Добавлена опция для вкл и откл отступов.- Другие мелкие изменения.
Arindel you would not do here such changes in skine or plug these changes in tuning, that in place of earpiecess there was a logotype of aipm,I on kavere in place of note as serdcy was the logotype of aimp as on skrine fastpic СПАММ[/color].ru/]
