Я пишу Nero Express. Она и весит мало, и устанавливается лихо, и работает быстро. И что не маловажно - она на русском языке. Пишу ею.
Пользователь, под линухом то k3b таки используешь?
It’s AliveAugust 12th, 2009 The project is very much alive although it’s been a while since the last release. A new version is scheduled for release the upcoming weekend. Version 0.50 contains some feature improvements but most importantly it addresses many of the bugs in previous versions. Much effort has been put towards ensuring the integrity of files written to CDs and DVDs. The device detection system has also been remade in order to solve drive letter detection problems and the infamous “disabled OK-button” bug. Translators should check here for information on changes. http://infrarecorder.org/?p=109
InfraRecorder 0.60Target release date: Autumn 2009. * Modularize burning back-end, adding support for other back-ends like Windows built in recording facilities.InfraRecorder 0.50Target release date: August 16th 2009English translation update: Click here. * Major bug fixes and various improvements.
[InfraRecorder-lang] Updates for Version 0.50From: Christian Kindahl <christian.kindahl@gm...> - 2009-08-12 20:53Hello everyone,Here are the changes for version 0.50. Please e-mail me thetranslation of the strings directly in an e-mail or apply the changesto your translation file and then e-mail it to me (preferred).The following strings have been added:[strings]0x013d=Unable to import, does the selected source file exist?0x013e=Could not import the file "%s".0x013f=Drive0x0140=Directory "%s" does not exist. Do you want it to be created?0x0141=Cannot create directory "%s".0x0142=The project file \"%s\" could not be found on your computer. Itwill be removed from the project.0x0143=InfraRecorder was unable to find any disc devices in yoursystem.\n\nPlease note that Windows 2000, XP and 2003 systems requireadministrator permissions to access disc devices. Often this can becircumvented by changing your system settings. Please consult theInfraRecorder FAQ in the manual for further information.The following strings have been removed:[device]0x0428=Silently validate the configuration at each startup[strings]0x0016=Loading extended device information...0x012a=Unable to open device, can not continue.Thank you!Regards,Christian
InfraRecorder 0.50В кач!
