~ inxi -FxxzSystem: Kernel: 6.18.8-3-cachyos arch: x86_64 bits: 64 compiler: clang v: 21.1.6 Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A wm: kwin_wayland dm: SDDM Distro: Manjaro base: Arch LinuxMachine: Type: Desktop Mobo: Micro-Star model: PRO B650M-P (MS-7E27) v: 1.0 serial: <superuser required> Firmware: UEFI vendor: American Megatrends LLC. v: 1.G0 date: 06/20/2025CPU: Info: 6-core model: AMD Ryzen 5 7500F bits: 64 type: MT MCP arch: Zen 4 rev: 2 cache: L1: 384 KiB L2: 6 MiB L3: 32 MiB Speed (MHz): avg: 4803 min/max: 428/5077 boost: enabled cores: 1: 4803 2: 4803 3: 4803 4: 4803 5: 4803 6: 4803 7: 4803 8: 4803 9: 4803 10: 4803 11: 4803 12: 4803 bogomips: 88799 Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svmGraphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 44 [Radeon RX 9060 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-4 pcie: speed: 32 GT/s lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7590 Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 4160x1440 display-ID: 0 Monitor-1: DP-2 pos: primary,left model: MSI G274QPF res: 2560x1440 hz: 165 dpi: 108 diag: 685mm (27") Monitor-2: HDMI-A-1 pos: right model: BenQ BenQGL2040M res: 1600x900 hz: 86 dpi: 92 diag: 506mm (19.9") API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1 glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9060 XT (radeonsi gfx1200 LLVM 21.1.6 DRM 3.64 6.18.8-3-cachyos) device-ID: 1002:7590 display-ID: :0.0 API: Vulkan v: 1.4.335 surfaces: N/A device: 0 type: discrete-gpu driver: mesa radv device-ID: 1002:7590 Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info x11: xdpyinfo, xprop, xrandrAudio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie: speed: 32 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab40 Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16 bus-ID: 12:00.6 chip-ID: 1022:15e3 API: ALSA v: k6.18.8-3-cachyos status: kernel-api with: aoss type: oss-emulator Server-1: sndiod v: N/A status: off Server-2: JACK v: 1.9.22 status: off Server-3: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: pluginNetwork: Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel pcie: speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0 chip-ID: 10ec:8125 IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>Drives: Local Storage: total: 3.22 TiB used: 1.3 TiB (40.6%) ID-1: /dev/nvme0n1 vendor: A-Data model: LEGEND 960 size: 1.86 TiB speed: 63.2 Gb/s lanes: 4 serial: <filter> temp: 38.9 C ID-2: /dev/sda vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB speed: 6.0 Gb/s serial: <filter> ID-3: /dev/sdb model: 240GB SSD size: 223.57 GiB speed: 6.0 Gb/s serial: <filter> ID-4: /dev/sdc vendor: Generic model: MassStorageClass size: 232.19 GiB type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 serial: <filter>Partition: ID-1: / size: 97.87 GiB used: 62.88 GiB (64.2%) fs: ext4 dev: /dev/sdb1 ID-2: /boot/efi size: 122 MiB used: 25.9 MiB (21.2%) fs: vfat dev: /dev/sdb2 ID-3: /home size: 120.95 GiB used: 21.92 GiB (18.1%) fs: ext4 dev: /dev/sdb3Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3Sensors: System Temperatures: cpu: 47.0 C mobo: 42.0 C gpu: amdgpu temp: 49.0 C mem: 67.0 C Fan Speeds (rpm): N/A gpu: amdgpu fan: 78Info: Memory: total: 32 GiB note: est. available: 30.94 GiB used: 7.1 GiB (23.0%) Processes: 563 Power: uptime: 26m wakeups: 0 Init: systemd v: 258 default: graphical Packages: pm: pacman pkgs: 1605 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
inxi -Fxxz System: Kernel: 6.18.8-3-cachyos arch: x86_64 bits: 64 compiler: clang v: 21.1.6 Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A wm: kwin_x11 dm: SDDM Distro: Manjaro base: Arch LinuxMachine: Type: Laptop System: LENOVO product: 81X8 v: IdeaPad 3 15ITL05 serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ITL05 serial: <superuser required> Mobo: LENOVO model: LNVNB161216 v: SDK0T76466 WIN serial: <superuser required> part-nu: LENOVO_MT_81X8_BU_idea_FM_IdeaPad 3 15ITL05 Firmware: UEFI vendor: LENOVO v: GCCN21WW date: 06/11/2021Battery: ID-1: BAT0 charge: 28.6 Wh (99.3%) condition: 28.8/35 Wh (82.2%) volts: 8.35 min: 7.6 model: LGC L16L2PB3 serial: <filter> charging: status: not charging cycles: 138CPU: Info: quad core model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP arch: Tiger Lake rev: 1 cache: L1: 320 KiB L2: 5 MiB L3: 8 MiB Speed (MHz): avg: 400 min/max: 400/4200 cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 bogomips: 38707 Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmxGraphics: Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo driver: i915 v: kernel arch: Xe ports: active: HDMI-A-1,eDP-1 empty: none bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 bus-ID: 3-5:3 chip-ID: 174f:118d Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9 compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1 Screen-1: 0 s-res: 3840x1080 s-dpi: 96 Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,right model: HP 24f res: N/A dpi: 93 diag: 604mm (23.8") Monitor-2: eDP-1 pos: left model: BOE Display 0x0700 res: 1920x1080 hz: 60 dpi: 142 diag: 395mm (15.5") API: EGL v: 1.5 platforms: device: 0 drv: iris device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris inactive: wayland API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.4-arch1.1 glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL GT2) device-ID: 8086:9a49 API: Vulkan v: 1.4.335 surfaces: N/A device: 0 type: integrated-gpu driver: mesa intel device-ID: 8086:9a49 Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor gpu: gputop, intel_gpu_top, lsgpu wl: wayland-info x11: xdpyinfo, xprop, xrandrAudio: Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 API: ALSA v: k6.18.8-3-cachyos status: kernel-api with: aoss type: oss-emulator Server-1: JACK v: 1.9.22 status: off Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: pluginNetwork: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3 chip-ID: 8086:a0f0 IF: wlp0s20f3 state: up mac: <filter> IF-ID-1: amn0 state: unknown speed: 10000 Mbps duplex: full mac: N/ABluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 3-10:4 chip-ID: 8087:0aaa Report: rfkill ID: hci0 rfk-id: 2 state: up address: see --recommendsRAID: Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd v: 0.6 bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0bDrives: Local Storage: total: 238.47 GiB used: 123.62 GiB (51.8%) ID-1: /dev/nvme0n1 vendor: Lenovo model: UMIS RPJTJ256MEE1OWX size: 238.47 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 32.9 CPartition: ID-1: / size: 107.72 GiB used: 52.84 GiB (49.1%) fs: ext4 dev: /dev/nvme0n1p1 ID-2: /boot/efi size: 99.8 MiB used: 302 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p5 ID-3: /home size: 122.11 GiB used: 70.78 GiB (58.0%) fs: ext4 dev: /dev/nvme0n1p8Swap: ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p7 ID-2: swap-2 type: zram size: 11.48 GiB used: 1.6 MiB (0.0%) priority: 100 dev: /dev/zram0Sensors: System Temperatures: cpu: 47.0 C mobo: N/A Fan Speeds (rpm): N/AInfo: Memory: total: 12 GiB available: 11.48 GiB used: 5.88 GiB (51.2%) Processes: 337 Power: uptime: 16m wakeups: 0 Init: systemd v: 258 default: graphical Packages: pm: pacman pkgs: 1641 Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
