can you open (and then close) the playlist window from the mini player? I see there is an action provider acformstoggleplaylistvisibility but when linked to a button on the miniplayer it doesn't work... it's my fault somewhere or is not possible?I am doing a project from blank and my playlist window is called 'PLISTwindow'
to have the waveform displayed as separate sticks instead as continuous line (i've seen it in some skins ) do you apply a mask on top of the waveform or there is a format command to display it like that?
first answer > what a fine tuning you made available! I have just tested and it's ok for me BUT this happens: I have the main window with playlist open and minimize to miniplayer> playlist disappear > i press the toggleplaylistvisibility button on the miniplayer AND STILL the playlist doesn't appear (it is being closed from miniplayer even if it is not visible) > i press again the button AND the playlist appear (nothing wrong for me, but YOU choose what to do)
I was thinking about the waveform as it is displayed on the mobile version (which you can use as a seekbar too) it is made of tiny sticks and i saw on some screenshot on the skin section (not one in particular i remember)
you find attached my project. It's still a work in progress but gives you the idea. The idea is to launch AIMP as tiny player like a desktop widget and switch it to main when needed so I think to have a playlist available also in tiny mode to see what is left to play. Also it is intended for single playlist use.
But cannot get this to work...
Why if I put %length(%value) to the output of prvplaybackqueue\status it returns 1 ?This is what I struggle to comprehend...
use AIMP v. 5.30.2549 with the latest skin editor (which is 5.40.14.29)
