DennoN
[?] [3031] [LINUX] AIMP freezes while trying to open an audio file
Topic: [?] [3031] [LINUX] AIMP freezes while trying to open an audio file (Read 673 times)
mirw3b
and 1 Guest are viewing this topic.
January 21, 2026, 19:24:41 »
mirw3b
Since few versions of aimp6, on linux, it just freezes. i used to just have to restart aimp after force-closing it, but now i just can't use it at all.
If i try to open an audio file, it stays on "Opening..." and doesn't play the audio file. And if i try to play the audio file again, then aimp just freezes.
I did try to fully uninstall aimp (and deleted all the folders and files of aimp, even in /opt/AIMP and in ~/.config/AIMP) but after reinstalling, i was only able to play an audio file once, after the audio finished, the issue was back.
I would say that the issue has been happening for around 2-3 weeks.
If this can help, i'm using Artix Linux on Wayland & Pipewire and i'm on KDE Plasma.
Last Edit: January 22, 2026, 14:48:46 by Artem
Re: [3031] [LINUX] AIMP freezes while trying to open an audio file
January 22, 2026, 14:48:25 »
Карма: +3176/-76
Please, send to me a screenshot of your playback output settings (first sheet in app settings).
Re: [?] [3031] [LINUX] AIMP freezes while trying to open an audio file
January 22, 2026, 16:35:51 »
mirw3b
Here, i also added another screenshot with all the other devices that show up in Sound Output.
January 22, 2026, 22:47:20 »
Карма: +3176/-76
Please, try to use ALSA-output. Will it freeze?
January 22, 2026, 22:53:02 »
mirw3b
Yes, even with Alsa it does freeze.
January 23, 2026, 08:58:56 »
Карма: +3176/-76
Quote from: mirw3b on January 22, 2026, 22:53:02
Please, can you share a log file with ALSA output?
January 23, 2026, 14:49:17 »
mirw3b
Yes, and i also tried switching to another Alsa output to check and it happens on other Alsa outputs too.
DennoN
