I have many m4a files containing FLAC audio, and AIMP does't seem to be able to read the cover art.Please advise.
If it has a .M4A extension, it's supposed to be AAC audio
And what about ALAC?In general, m4a stands for MP4 Audio. The mp4 container in such a file can contain an audio stream in any registered format.Are you sure those files were misformed? Encapsulation of FLAC in ISO Base Media File Format.
If it has a .M4A extension, it's supposed to be AAC audio, which uses MP4 tags, not FLAC, which uses Vorbis tags No wonder AIMP is confused.This is a file problem--wrong extension or container for the actual codec--not an AIMP problem.Artem, I hope the "fix" you made to the player so it displays tags from these misformed files wasn't at the expense of compromising standards adherence.
Also, as a container, M4A can have many types of audio formats.There really is no need to discuss anything else here on this topic unless there's a problem with the fix once it's released.I'm happy for Artem's support
... defining what may continue to be discussed here or anywhere else is Artem's or a moderator's decision.
My final comment is that surely FLAC codec audio is "best" contained in the container format designed specifically for it, with its metadata tags conforming to the type defined for them, Vorbis comment, as defined in section 8.6 of the RFC 9639 doc (https://datatracker.ietf.org/doc/rfc9639/). You can plug content into various containers and have it played, but by conforming to one standard all players know how/what they are dealing with and avoid confusion. Here is an incident that points this out: https://hydrogenaudio.org/index.php/topic,125673.0.htmlThe RFC 9639 doc in the #10 Container Mapping section, points out some facts with potential for problems when non-FLAC containers are used:...etc etc...
