I want to remove the yellow marked infos but I can't find how.
I really don't need are there again. How? I edited it..
And is there a way to remove the bookmark category too?
I just need a list of my titles with playcounts and simple buttons (not a separate one for play AND pause AND stop).
But where do I remove them? As you can see it's not in the same place as last time. And I can't find another place where they might be.
But if you look at my screenshot you see, that the field you showed doesn't show the information about mp3 and Hz and all that. And since it isn't showing it, I'm not really sure, where it comes from and how to remove it.
Mareala 4 as stated above.
