Total Members Voted: 2
Nothing changed just a normal update.
several bugs
lack of features please view it
On my old device models after a quick start it shows loading files for 1 secs which is improved.
App sometimes automatically select all songs on search results
After few updates it automatically switching reverting to first song on list in search results or normal placing, i checked all options before posting here.
*Own volume panel which displays volume level*Inbuilt limiter for system and app equal.*32, 31 bands equalizer.*Direct volume control.*Septrate bass option without turning on equalizer.*Display bt codec and information.
1 )In Poweramp, DVC stands for Direct Volume Control. It's an Android-specific feature that allows the app to bypass the Android system's audio processing (including the equalizer, sound effects, and volume control) and send the audio output directly to the device's DAC (digital-to-analog converter). This can result in a cleaner audio signal and potentially a higher volume on some devices, as it bypasses the Android system's volume limitations and processing. 2)Poweramp music player for Android offers a 32-band graphic equalizer, allowing for detailed sound adjustments. This feature enables users to customize the audio output with a high degree of precision, spanning from 5 to 32 bands. The default setting is 10 bands, but users can configure it to their preference. 3)Poweramp provides separate bass control through its Equalizer feature. Users can adjust the bass levels using the built-in equalizer, including creating and saving custom equalizer presets. The equalizer allows for adjustments to specific frequency ranges, including bass, and also offers options for bass boost or cut. Very useful for bass lovers.3)By providing visibility into the active Bluetooth codec, Poweramp helps users understand the actual quality of their wireless audio transmission and make informed decisions about their device settings and expectations for sound quality.
