Didn't understand. What is the essence of a suggestion?
The suggestion is to show, on the window that adds files to the playlist, the files that the system decoders supports when the internal decoder is unload.
Windows does not provide a list of file extensions, so you cannot display it. Just only try to decode the file. What file format you want to decode?
Just play FLAC files.
