AIMP 4https://www.aimp.ru/blogs/?p=1285If the device is compatible (see the information on the site), then install the latest version. It is not necessary to uninstall the old version.If the device is not compatible, then older versions of the player are available on the site. Accordingly, the functionality is old.Google Play (if available) must comply with the compatibility conditions. Except for very old OSes, where Google has dropped support.If you are using a skin for an older version of the player, you may not find the functionality. Something like that was mentioned.
