but doesn't work with mp3
double backlash (\\) for multiple artists?
Double backslash is not used in ID3 standard
The problem is that the double backlash (\\) is used by mp3tag, and maybe other tools tool. What could I do as a user if it seems that there is no agreement regarding the processing and tagging of albums with multiple artists?
If it turns out that the semicolon is used not only by AIMP, but also by most music players, do you think I could suggest on the mp3tag forums to allow users to use the semicolon instead of the double backlash (\\)?
Here goes a sample:https://drive.google.com/file/d/1K_k2jMsHje05EQmXi8gM7lmx2EuSE2Ma/view?usp=sharing
So, the file displays correctly in latest AIMP version (and it does not contains double backslashes, values stored according the standard).
Try on this build:https://disk.yandex.ru/d/vrOPJIJ8is7KsQ
Will this enhancement be included in the next stable release of AIMP?
Yes
Also, if it's possible, could you please add this feature to the incoming new version for Android? Having the same experience on mobile would be awesome!
