DennoN
AIMP: Code: -1 (FFFFFFFF)
Topic: AIMP: Code: -1 (FFFFFFFF) (Read 900 times)
January 04, 2023, 02:58:27 »
Darth2602
Hello, I can't read the M4A files, I have a message
Message: Decoder was not found for this format.
I could read them before... I didn't make any modification in my pc configuration, I just have the latest version of Aimp
Здравствуйте, я не могу прочитать файлы M4A, у меня сообщение
Message: Decoder was not found for this format. / Декодер не найден для данного формата
Я мог читать их раньше... Я не вносил никаких изменений в конфигурацию своего ПК, у меня только последняя версия Aimp.
Last Edit: January 04, 2023, 03:18:04 by Darth2602
Re: AIMP: Code: -1 (FFFFFFFF)
January 04, 2023, 03:03:26 »
Супермен
Карма: +395/-67
1. Rules for creating topics - use a translator if the language is not native.
https://www.aimp.ru/forum/index.php?topic=5451.0
2. Check connected plug-ins in the player and sound output device.
3. Check for a portable or no-install version.
January 04, 2023, 03:26:31 »
Darth2602
I tested
- "Direct sound - Nvidia High definition audio"
- "Direct sound - Windows default"
- "WASAPI - Windows default"
I have no additional plugins
Я протестировал
- "Прямой звук - Nvidia High definition audio"
- "Прямой звук - Windows по умолчанию"
- "WASAPI - Windows по умолчанию"
У меня нет дополнительных плагинов
January 04, 2023, 03:32:50 »
Супермен
Карма: +395/-67
Are all plugins enabled?
__
Does the error occur on the portable version?
January 04, 2023, 03:34:59 »
Супермен
Карма: +395/-67
It is desirable to give a link to the file, because the player may not support the codec.
The format (container) is like a package. It can contain "edible" data ("food") or "non-edible".
January 04, 2023, 12:52:26 »
Darth2602
- These are files that have been read before by old AIMP versions (installed version),
- all plugins are activated
After checking the box Autorization of the use of system décoder , AIMP can read the files
DennoN
