Automatic synchronization was not yet implemented, but you can export your playlists with relative to music paths and transfer it to music folder in mobile, next import these playlists to player
PC.Export (save) = ctrl+s.Additional: Disable "Save absolute file paths (recommended)".Android.Import.Arrange files in the same way as PC files so that the player can find them.
