How to reproduce it?P.S. on restart, app should scroll the list to row that you've selected. This is correct behavior.
yes but its not working for all the album in the artists it start from first second and then nothing
to reproduce it select an artist play a track from an album then scroll above or below to not visible through the list then on mouse plasment at the artist list the autoscroll enabling
Hm, its not related to playback. I mean that app restores selection and make focused row visible. Thats all.Yes, I remember this action on your video, but as I say above, app will restore viewport on focused element (not on viewport position that you set manually). It was made, because viewport is depended from skin settings and it layout, and may be changed during resize the window (as reaction to change of screen resolution, for example or some other external event). So, app scrolls the list to your selection. I think that behavior is more useful.
