Get rid of audio pattern and just have a simple slider instead
For playlist I would like to use different font and change it's size
Are you referring to the "Show waveform of playing file over the seek bar" option in Prefs/Interface/Skins? If so, just un-checking that will return the slider.
By "default skin", do you mean the standard skin for AIMP 4.70, Bliss 4K? If so, you can do those changes and many more using the AIMP Skin Editor application. I have the same screen res as you but with 100% scale in Windows, and have AIMP's Interface scale factor set to 125% with text size at 110%. With the Skin Editor, I have additionally changed the type face and size of the text on the main player body to my own visual preferences, which can also be done to the Playlist font.
