AIMP for Android v4.20
Player no longer goes in to minimize mode?
Topic: Player no longer goes in to minimize mode? (Read 5559 times)
November 28, 2020, 11:17:08 »
Sosobra
Since the most recent update, when I put the player into minimize mode (no matter what skin I'm using) it just goes away... It's still in the taskbar / tray but I have to go to the tray and click "Minimize To Tray" off to get the mini player back!
I've gone through all the settings and everything is looking how it's supposed to! Help!!!
Re: Player no longer goes in to minimize mode?
November 28, 2020, 20:02:34 »
Карма: +3179/-76
Make sure that main window of the app does not attached to screen edge.
November 28, 2020, 22:55:31 »
Sosobra
Yes, it's not docked, although it's set to floating with auto-hide and I can't switch that (they are greyed out)
November 29, 2020, 06:53:40 »
Sosobra
Fixed it!
January 26, 2021, 01:17:55 »
L3g0n00b
Quote from: Sosobra on November 29, 2020, 06:53:40
Fixed it!
How did you do that? I have the same problem. It is set to "undock" but I can't move it
