AIMP для Windows
Skin Editor / Skin Engine
Вопросы
How to make a button choose a specific value
Topic: How to make a button choose a specific value (Read 459 times)
September 29, 2020, 12:45:39 »
Gilang4321
So i have 3 images in "Texture ex" and i create scriptableoperatorcounter to connect it with button and a panel
so when i click button 1 it will show image(value1) one the panel, when i click button 2 it will show image(value2) on the panel and next
but when i use (value+1) in button link options it keeps changing the image not the specific image that i want ...
anyone know how to do that?
Re: How to make a button choose a specific value
September 29, 2020, 13:52:00 »
Супермен
Карма: +2733/-48
if I understand you correctly, you should replace value+1 expression with specified value: 1, 2, etc
September 30, 2020, 02:03:26 »
Gilang4321
thanks it worked
now how to change a color when i click button 1 it the skin color will change to red and when i choose button 2 to blue? (rgb color)
AIMP для Windows
Вопросы
