ERROR:: WHILE LAUNCHING AIMP on WINDOWS 10 x64
Topic: ERROR:: WHILE LAUNCHING AIMP on WINDOWS 10 x64 (Read 2957 times)
September 14, 2020, 15:34:20 »
AVI_RA
Hello,
While launching AIMP on Windows 10 x64, I am getting the attached error. I tried both exe version and app from Microsoft Store. And I am getting the same error on both occasion. I am fairly certain that my system is CLEAN and there is no infection. I use Applocker, Exploit Protection and ESET as security measures.
I did some google and found only 2 occasions where some users mentioned this type of error and in both occasions it's related to bass_aac.dll. I was wondering if someone can tell me what kind of this error is all about?
Re: ERROR:: WHILE LAUNCHING AIMP on WINDOWS 10 x64
September 14, 2020, 15:37:55 »
Карма: +1371/-187
https://www.virustotal.com/gui/
September 14, 2020, 15:58:07 »
AVI_RA
Hi, Solo!
I didn't understand what you'd like to say? I am aware of VirusTotal, and as I said in my previous thread, I have downloaded AIMP from AIMP.RU and even installed the Windows App store version from Microsoft App Store too. In both cases, I am receiving the same error.
September 14, 2020, 16:17:25 »
Карма: +455/-73
Often this error is not related to viruses.
Several cases are possible:
Parameters of system variables are violated, therefore, files are scanned at an incorrect address;
We will damage the non-system file guard32.dll in the system folder or some application created it;
Similar situations with damaged system addresses and copying unnecessary files to the system folder.
So search for duplicates of all files on your computer by their name and remove (rename) that may be causing the problem. Also check the system variable entries and remove extraneous ones.
All this must be done with caution and not be able to undo the changes. As a last resort, you may need to reinstall / return the system to its original state.
https://www.un4seen.com/forum/?topic=14460.0
https://forums.comodo.com/virusmalware-removal-assistance/xmplay-error-this-file-has-been-tampered-with-and-may-be-infected-by-a-virus-t42132.30.html
etc. links
September 14, 2020, 16:26:28 »
AVI_RA
Can this error may related to Mandatory ASLR and CFG (Control Flow Guard)?
