[x] Podcast duration format issue
Topic: [x] Podcast duration format issue (Read 1404 times)
August 26, 2020, 20:57:36 »
hcann
Hi Guys,
I noticed if a duration has a decimal point the duration won't show in AIMP eg:
http://www.newstalk.ie/content/001/podcastFeeds/271.xml
=> <itunes:duration>1297
.00
</itunes:duration>
However, durations without decimal points will show fine e.g.
https://www.newstalk.com/content/001/podcastFeeds/539.xml
<itunes:duration>394</itunes:duration>
Is there a way to alter the feed url for the duration to show or some setting I can change?
Thanks
Last Edit: August 27, 2020, 13:29:30 by Artem
Re: [x] Podcast duration format issue
August 27, 2020, 13:29:58 »
Супермен
Карма: +3114/-70
Fixed, thank you. Please way for next update.
