What exactly you want to remove from the menu? I planning to make possible to switch off features (remove commands) from all menus
mostly to disable it! but if you already plan it will be so awesome!!! that's why I love aimp for the flexibility of customisation it have
What commands exactly you will remove from the menu?
m to be precise even better to disable the context menu of tray icon
Entire menu? What reason for? How you will restore the player if restore command is not set on clicks?
