Al_kat_raz and 2 Guests are viewing this topic.
What sites were you trying it with? Youtube or something else?Problems on first run could be because it downloads/updates the youtube-dl.exe, I should probably run that on separate thread and display someting if you try adding/playing url while it's downloading.I've been trying clicking on stuff aggressively and fixed some memory leaks/access violations the AIMP debug version was reporting in 2.0.1 and can't really reproduce any crashes anymore.
Tried to use this version. I have this -->
Thanks for the plugin and improving it. Although it works it only loads the first item of a private playlist when i try to add the playlist. It works fine on unlisted playlists. Also it would be really good if it can pre-load video durations.
v2.0.2 - https://github.com/jaryn-kubik/AimpYouTubeDL/releases/tag/2.0.2
