AIMP for Android v4.00
Is there a save option (not "save under") to just save the running playlist?
Topic: Is there a save option (not "save under") to just save the running playlist? (Read 1372 times)
July 17, 2022, 11:43:44 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
Is there a save option (not "save under" by pressing CTRL+S) that allows to just save the running playlist without the save dialog (opening window and the search the album folder and then press save)?
Re: Is there a save option (not "save under") to just save the running playlist?
July 17, 2022, 20:04:21 »
Супермен
Карма: +2931/-56
Player does it automatically. You not need to save changes in playlists by yourself
