First, you should publish your skin in our forum: https://www.aimp.ru/forum/index.php?board=14.0 , you should read board rules first https://www.aimp.ru/forum/index.php?topic=4928 . After testing the skin, you can send request to publish skin in the catalog (refer the https://www.aimp.ru/forum/index.php?topic=4928.msg168553#msg168553)
Hi, when I have prepared the image file, description file, zip file of the whole project, where should I post it for publication? Where do I put it to be seen for publication in the skins section?
Hello, what should I do if I want to update the skin I have published?Do I have to publish a new post, or can the same post be updated?
when I design an image (a button or album cover frame) in graphic software and use it in the skin editor, the image quality decreases and the edges of the image become pixel and serrated. What is the problem? Do I have to do anything special when creating or outputting a graphic file?
Your skin moved to: https://www.aimp.ru/forum/index.php?board=14.0Then will be published on main skin page.
I’ve been looking for an old skin for Aimp for years which I loved very much but unfortunately I’ve already lost. Maybe you can help me. Thank you very much!
