How to play MIDI files
Topic: How to play MIDI files (Read 24417 times)
December 14, 2017, 12:57:35 »
Gruko
Карма: +2/-0
Hi,
I'm trying to play some midi file downloaded from here
http://www.angelfire.com/fl/herky/sounds.html
but without results.
Should I activate some options?
Re: How to play MIDI files
December 14, 2017, 13:02:25 »
Карма: +1367/-187
https://www.aimp.ru/forum/index.php?topic=259.msg201508#msg201508
December 14, 2017, 13:20:45 »
Gruko
Карма: +2/-0
Thank you very much!
October 03, 2018, 02:41:59 »
Decat24
Hi,
I too couldn't play MIDI files in AIMP player. When I attempt it I hear nothing. Could you explain it to me in English, because I couldn't understand the previous post.
October 03, 2018, 06:33:30 »
sveakul
Карма: +77/-1
Decat24: you need to have a soundfont file installed first to play MIDI; the soundfont file contains the library of sounds/timbres used to reproduce the music in the midi audio. In AIMP, go to Preferences/Plugins/Decoders/MIDI, and click the little "wrench" image to the right of the entry; then in the MIDI settings window, browse with the "..." button to point the plugin to wherever you have placed the soundfont file:
I have attached (un-zip it) a small basic soundfont file you can try, but you can find much more sophisticated and complete soundfonts by just googling "free soundfont files." Some good ones are "GeneralUser GS MuseScore", "OmegaGMGS2", and "Timbres of Heaven."
January 23, 2021, 22:25:17 »
Nemo56
Is it possible to select a different midi output device instead of the integrated one?
January 24, 2021, 13:04:23 »
Карма: +3130/-71
yes, refer to first page in settings dialog
January 30, 2021, 12:17:11 »
Nemo56
Hmmm ... there I could only find the sound output (Soundcard, Directsound, Wasapi and so on), but not an option whatr to use to playback MIDI files (Microsoft GS Wavetable Synth, VirtualMIDISynth, Fluidsynth, ...)
Reply #8 on:
January 30, 2021, 13:52:05 »
Карма: +3130/-71
Oh, I understand what are you talking about. No, AIMP can output the PCM signal only
Reply #9 on:
February 06, 2021, 10:51:53 »
Nemo56
ok, thanks for the reply.
