https://yadi.sk/d/-Dacp9J83YuFWB
There is a memory leak after the player is closed.The log was obtained using this debug build:Also after restarting the player with active DLNA tab, the tree on the left becomes empty. You need to manually press F5 in the music library to get a content of the tree back.
Yea, you have to manually refresh for now as I had problems with signalling aimp that the tree has changed.
Maybe MusicLibraryDemo (DemoExplorerView) from the SDK will help you?
A memory block has been leaked. The size is: 36This block was allocated by thread 0x53C0, and the stack trace (return addresses) at the time was:0176a1d8 +04 AIMP.Runtime.dll System 4755 +20 @GetMem01249d6a +6e AIMP.Shared.dll AIMP.Core 348 +3 TAIMPCore.RegisterExtension012e37ef +63 AIMP.Shared.dll AIMP.Plugins 657 +5 TAIMPPluginPresenter.RegisterExtension012e2fab +5f AIMP.Shared.dll AIMP.Plugins 461 +7 TAIMPPlugin.Initialize012e4d47 +0f AIMP.Shared.dll AIMP.Plugins 1000 +2 TAIMPPluginManager.LoadThe block is currently used for an object of class: TAIMPMLGroupingPresetsAdapter
All memory leaks should be fixed.
v2.2.0.0On this build: https://yadi.sk/d/-Dacp9J83YuFWBAfter AIMP exit
Whoops. Fixed.
Cool!v2.2.1.0not always shows all serversafter installation of the plug-in - all servers are visibleafter AIMP exit and run AIMP again - not all servers are visibleit occurs not always, but is frequent
or right click and select refresh.
i have no this menu item
Did the 1s delay help?
yesbut on feelings it is a big delayit is possible to make less
