But neither opening the .cda files directly nor dragging the Drive-Icon into AIMP playlist nor manually opening the files via menu -> open folder/files in AIMP let it play the audio disc...
Does AIMP show any .cda files in file dialog? Make sure that CDDA Decoder plugin is loaded into AIMP
How can I check whether the .dll's are loaded when AIMP is running?
preferences / plugins / decoders -> checkbox "Compact Disk Digital Audio"
