Total Members Voted: 121
Here's a modified plugin that allows you to use your own API keyAdding URLs works out of the box - the default API key is replaced with a new one.If it stops working, you need to use your own one (see instructions below)You can specify your own API Key, Client ID, Client Secret - without these credentials, any account-related features will not workChannel name in the Artist tagVideo description in the Comment tag" - Topic" is automatically removed from channel namesDownload (MEGA) (OneDrive)Setting up Google API credentials (API Key, Client ID, Client Secret)Create a project, enable YouTube API, obtain Client ID and Client Secret: guide(You can skip steps 3 and 4 if you only need the API key)Important notes:Step 3: you need to check both '.../auth/youtube.readonly' (View your YouTube account) and '.../auth/youtube' (Manage your YouTube account)Step 4: select 'Desktop app' for Application TypeClick 'Create Credentials' once again and select 'API key'. It will be generated and added to the credentials pageOpen AIMP settings > profile folder > AIMPYouTube > Config.jsonFind "UserAppKey": "...", "UserClientID": "" and "UserClientSecret": "" lines and paste your API Key, Client ID и Client Secret in the quote marks respectivelyRestart AIMPOpen plugin settings and log into your YouTube account
Yeah, I've generated mi Google API Key, but I don't know where is supposed I have to paste it
Без Ключ API вообще не будет работать? Какие есть варианты без этого
вернул стандартный API Key т.к. он снова работает.
Возможность указать свои API Key... ...в случае, если плагин перестал работать.
{ "Exclusions": [], "MonitorURLs": [ { "URL": "https://www.googleapis.com/youtube/v3/videos?part=contentDetails%2Csnippet&hl=ru&id=jfKfPfyJRdk", "Flags": 2, "PlaylistID": "{B94EDBB4-E22F-41D3-BBCC-E6E25FF7F3BD}", "GroupName": "YouTube" } ], "UserPlaylists": [], "UserAppKey": "", "UserClientID": "", "UserClientSecret": ""}
удалил, ничего
