Total Members Voted: 106
Is there permanent fix for this plugin? My playlists from you tube doesn't work either. Whenever it gets patched, it starts crashing after a week or so. It's great idea, but not really best execution. I know it's free and I should be grateful, but.. Ah, nevermind, all cool!
As long as youtube keeps changing their backend, this will keep breaking, there's really no way around that. Updating the youtube-dl.exe with the Update button in Options->Plugins->Youtube should usually be enough though, it gets updated pretty quickly whenever it breaks (usually the same/next day). I could try to automate the updating, but didn't really have time for it yet. Also clicking on it manually is always gonna be less buggy anyway.Also generally if you're sure you updated the youtube-dl.exe and it's still not working then post the exact links that don't work. I'm using this daily with no issues, so clearly there's a problem with different links/settings/os/whatever, but I can't possibly fix what I can't reproduce.
Ok, check mine:Hmm my version is 4.51 (build 2084).. Will check if there's newer one.
The plugin suddenly stopped from working for me too. Everything seems fine, (no updates available) except to play a song. Every song in all of my YouTube playlists in AIMP says "0kHz, 0kbps, 0Bytes" and when I click on some of them, AIMP just start to play my local music files. Different local song depending on which song from YouTube i wanna play.
