Oh, sorry. This is my fault.
button close eq - exit player
why with button close eq - exit player
Looks refreshing. But there are two little issues it seems1. AIMP skins typically leave main colour hue choice for user. Surely, skin artist sets the default one (light green-cyan in your case), but in Skin Settings dialog user can override it and the outlook instantly chsnges.2. the skin seems somewhat blurry on Win 8,1 HiRes ( aka 120-DPI in winXP terms) mode, maybe it is more about the engine than the skin itself, dunnohttps://yadi.sk/i/Nxe_nFsphBCCz
that was an error reportu passed two skins. The "transparent-header" one works okay, but the "opaque-header" one is broken - when you press "close equalizer" button it closes the player completely instead
