...I prefer to have the two windows chained.Is there a way to make the main window wider as well?Or is there a way to keep the width of the playlist even if I re-attach the playlist later?If this all does not work: Could you release a new version which allows this?Thank youPeter
...Maybe you could (as a small improvment) double the width of the main window (+ playlist). So both textures fit together.As another alternative you could (when floating playlist is attached to main window) adjust the main window width to that of the playlist. Unusual, but should be possible. The texture itself is stretchable as I resizing of the detached playlist shows.I really, really appreciate your skin. Maybe you could make it possible somehow :-)Thank youPeter
