Ну, я бы ещё понял, если б ты Wine под рутом запускал... а на дефолтных птичьих правах вирусне и ткнуться-то некуда.
## DO NOT EDIT THIS FILE## It is automatically generated by /usr/sbin/grub-mkconfig using templates# from /etc/grub.d and settings from /etc/default/grub#### BEGIN /etc/grub.d/00_header ###if [ -s $prefix/grubenv ]; then load_envfiset default="0"if [ ${prev_saved_entry} ]; then set saved_entry=${prev_saved_entry} save_env saved_entry set prev_saved_entry= save_env prev_saved_entry set boot_once=truefifunction savedefault { if [ -z ${boot_once} ]; then saved_entry=${chosen} save_env saved_entry fi}function recordfail { set recordfail=1 if [ -n ${have_grubenv} ]; then if [ -z ${boot_once} ]; then save_env recordfail; fi; fi}insmod ext2set root='(hd1,5)'search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332eif loadfont /usr/share/grub/unicode.pf2 ; thenset gfxmode=1024x768 insmod gfxterm insmod vbe if terminal_output gfxterm ; then true ; else # For backward compatibility with versions of terminal.mod that don't # understand terminal_output terminal gfxterm fifiinsmod ext2set root='(hd1,5)'search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332eset locale_dir=($root)/boot/grub/localeset lang=ruinsmod gettextif [ ${recordfail} = 1 ]; then set timeout=-1else set timeout=10fi### END /etc/grub.d/00_header ###### BEGIN /etc/grub.d/05_debian_theme ###set menu_color_normal=white/blackset menu_color_highlight=black/light-gray### END /etc/grub.d/05_debian_theme ###### BEGIN /etc/grub.d/10_linux ###menuentry 'Ubuntu, с Linux 2.6.32-24-generic' --class ubuntu --class gnu-linux --class gnu --class os { recordfail insmod ext2 set root='(hd1,5)' search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332e linux /boot/vmlinuz-2.6.32-24-generic root=UUID=868d03fa-4b73-4ce6-b39a-4dda21e5332e ro splash vga=773 quiet splash initrd /boot/initrd.img-2.6.32-24-generic}menuentry 'Ubuntu, с Linux 2.6.32-21-generic' --class ubuntu --class gnu-linux --class gnu --class os { recordfail insmod ext2 set root='(hd1,5)' search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332e linux /boot/vmlinuz-2.6.32-21-generic root=UUID=868d03fa-4b73-4ce6-b39a-4dda21e5332e ro splash vga=773 quiet splash initrd /boot/initrd.img-2.6.32-21-generic}### END /etc/grub.d/10_linux ###### BEGIN /etc/grub.d/20_memtest86+ ###menuentry "Memory test (memtest86+)" { insmod ext2 set root='(hd1,5)' search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332e linux16 /boot/memtest86+.bin}menuentry "Memory test (memtest86+, serial console 115200)" { insmod ext2 set root='(hd1,5)' search --no-floppy --fs-uuid --set 868d03fa-4b73-4ce6-b39a-4dda21e5332e linux16 /boot/memtest86+.bin console=ttyS0,115200n8}### END /etc/grub.d/20_memtest86+ ###### BEGIN /etc/grub.d/30_os-prober ###menuentry "Windows 7 (loader) (on /dev/sda1)" { insmod ntfs set root='(hd0,1)' search --no-floppy --fs-uuid --set 046cf2c66cf2b212 chainloader +1}### END /etc/grub.d/30_os-prober ###### BEGIN /etc/grub.d/32_WinXP_sda1 #### w7 on /dev/sda1menuentry "WinXP on /dev/sda6" { set root=(hd0,6) chainloader +1 }### END /etc/grub.d/32_WinXP_sda1 ###### BEGIN /etc/grub.d/40_custom #### This file provides an easy way to add custom menu entries. Simply type the# menu entries you want to add after this comment. Be careful not to change# the 'exec tail' line above.### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/30_os-prober ###menuentry "Microsoft Windows XP Professional (on /dev/sda1)" {essional (on /dev/sda1)" {y}save_env saved_entryprev_saved_entry=save_env prev_saved_entryfiinsmod ext2set root=(hd0,5)search --no-floppy --fs-uuid --set 31732ce0-9644-4f47-a6a0-67986da34464if loadfont /usr/share/grub/unicode.pf2 ; thenset gfxmode=640x480insmod gfxterminsmod vbeif terminal_output gfxterm ; then true ; else# For backward compatibility with versions of terminal.mod that don't# understand terminal_outputterminal gfxtermfifiif [ ${recordfail} = 1 ]; thenset timeout=-1elseset timeout=10fi### END /etc/grub.d/00_header ###
и да, не совсем понял, что вы предлагаете сделать с лоадером 7
Как я понял: Загрузить Windows 7, открыть список операционных систем, удалить оттуда Windows XP, затем добавить Windows XP в меню Linux'а
Встретил вот такое меню:
Информацию ищи здесьhttp://forum.ubuntu.ru/index.php?topic=74165.0а memtest - это проверка памяти на наличие неисправностей, выполняется пока сам не прервешь этот тест.
А чем вы свой убунту украсили?
