Total Members Voted: 27
You need to switch the option to 16 bit, there will be no problem.
Thanks for the reply, which option would that be? Somewhere in the AIMP settings?
I put it on DirectSound and 16bit and it's still crackling . This was my favorite plugin ever used on Winamp many many years ago it made everything sound so much better! Would love to get it working properly
I used to use it too until I switched to a high bit rate sound card.The problem with this plugin is that it works properly only in 16 bit mode.I can recommend you as an alternative Enhance Extra bass and treble plugin.
I tried it on this setting and I think it's working ok now, but on this setting It blocks every other sound the laptop wants to make lol. But as soon as I stop aimp from playing, then all the other laptop sounds start working again.
lol never mind, as soon as I made the post it started crackling after 45mins of music playing. Back to the other setting where it can only play audio from 1 program at a time.
I think for further sound upgrade you should move to professional bitrate there you don't need global improvements of this plugin.
I'm don't quite understand what you mean by this?
I have Windows running in 24 bit audio output mode, all content YouTube streams go without monopoly mode wasapi.Of course for this you need the appropriate hardware.
Same here I got mine in 24bit mode. I can change it to 16 bit right in the options there, but it makes no difference for AIMP issues with enhancer.
Yeah probably, I was looking at [DSP] [x32] Enhance Extra bass and treble that you posted. I remember using that version on Winamp probably more than 20 years ago I'll have to give that 1 a try
