AIMP for Android v4.20
[x] [3005] EurekaLog entries
Topic: [x] [3005] EurekaLog entries (Read 1293 times)
September 25, 2025, 20:40:00 »
sveakul
Карма: +78/-1
I gave it a brief try,3005 x64 Portable. Used custom version of Charm skin now used for AIMP 5.40.2694. Had some problems loading VST2 plugins, needed to be restarted between plugins for all 3 to display. Had it hang in Task Manager once, Anyway, not a fair test so no "bug report", just wanted to check it out to see if it could use my existing skin. No problems playing streams and displaying cover art and lyrics from the Internet.
One thing: the Portable will install a "bug reporter", Neos EurekaLog, with some of its components outside the AIMP folder (see below). This is an industry wide app used to help debug apps; so, nothing to worry about, but if you are deleting your AIMP6 Portable folder, you will have to delete this stuff manually to "get it all" (a shout-out to Regshot 1.9.1.321 x64!):
Folders added: 3
C:\Users\(user)\AppData\Roaming\Neos Eureka S.r.l
0x00000010
C:\Users\(user)\AppData\Roaming\Neos Eureka S.r.l\EurekaLog
0x00000010
C:\Users\(user)\AppData\Roaming\Neos Eureka S.r.l\EurekaLog\Bug Reports
0x00000010
Registry values added
HKU\(current user)\Software\EurekaLab\EurekaLog\7.0\MachineID: 5D EE A2 FC 9A E6 0E 49 BE AA D8 4D 97 16 4F DC
HKU\(current user)\Software\EurekaLab\EurekaLog\7.0\User\Email: "your-email@example.com"
Last Edit: September 26, 2025, 11:30:32 by Artem
Re: [3005] EurekaLog entries
September 25, 2025, 21:59:53 »
Карма: +3177/-76
Please, create a new topic for each issue.
