[x] [2683] Replay Gain normalization - analyse file on the fly issue
Topic: [x] [2683] Replay Gain normalization - analyse file on the fly issue (Read 2366 times)
June 27, 2025, 14:37:51 »
Arkon77
Replay Gain normalization - analyse file on the fly issue. Current max value never go above 1,00 dB
Last Edit: July 02, 2025, 23:29:24 by Artem
Re: Replay Gain normalization - analyse file on the fly issue
June 27, 2025, 15:25:32 »
Карма: +3129/-70
What app version you using? Currently maximum is +15 dB (of course, song should be too quiet)
June 27, 2025, 15:56:32 »
Arkon77
Latest version. I mean that this value from attached image never go above 1dB even on very quiet song. It can go far under but never up.
Re: [x] [2683] Replay Gain normalization - analyse file on the fly issue
July 03, 2025, 00:12:17 »
Карма: +3129/-70
Please, try this build:
https://disk.yandex.ru/d/DvX8Hodi5rsjzQ
July 15, 2025, 16:24:51 »
Arkon77
It looks like it works fine now. Thank you very much !
But it looks like 8dB is max for gain top value.
