If necessary I could upload an example of such ill TTAs - a one with no metadata and its doppelganger with half-invisible tag data
A TTA file created in AIMP Converter is able to receive text in e.g. the Title tag field in Mp3tag and I can save it - but the act of saving wipes the field clear in Mp3tag. The saved text is thus not visible in Mp3tag - but it is being displayed by the AIMP player and also by e.g. Winamp when such TTA is loaded to them. So my Mp3tag is unable to read the tag fields
so if you only write ID3 tags, they will not be displayed.
AIMP converter produces TTA files with both APE and ID3 tags.In Mp3tag, APE tags take priority even if they are empty, so if you only write ID3 tags, they will not be displayed.
You need to remove APE tags or write them along with ID3. See Mp3tag > File > Options > Tags > Mpeg
You mean the mp3tag does not mix data from different tags to show almost full information? O_o
the lack of option for wiping of tags in AIMP Converter during conversion is an inconvenience for me - and as existence of this topic shows, it can also lead to avoidable issues
Shockingly, yes. Enabled types in the "read" settings are not mixed, but displayed in priority order: APE > ID3v2 > ID3v1.
And so: the lack of option for wiping of tags in AIMP Converter during conversion is an inconvenience for me - and as existence of this topic shows, it can also lead to avoidable issues
[...]As for Mp3tag, please try the following settings:Options > Tags > Mpeg > Remove > ID3v2 > OFF[...]
So, what reason to use mp3tag? What features are missing in AIMP's tag editor?[...]
[...]why does >>APE 2<< used for >>Mpeg<< fixes this, while >>APE 2<< used for >>Ape, Mpc...<< does not?
[...]why do I have to use this >>Remove tag<< manual approach, if my Mp3tag explicitly uses the >>Remove<< options?[...]
[...]create a suggestion here[...]
But these two question remain[...]
But these two question remain i.e. the
