I use x64 libsoxr.Make rec dsd problems and rec2 with distortions. But i think rec2 is not enough to help fix distortions. I rec more, and send later.Link in gmail Artem
Almost perfect, but have problem with one song in dsd. No distortions, but time jumping.
In last 2673 Aimp still have problem with one song in dsd. During playing song aimp do few times pause.
In 44100 is ok. Can you Artem fix resampler ? Because is stupid remember changing frequency before playing DSD. What you think about fix it Best RegardsMaciejakThank You for fix problems
Now is ok with this set.
So, another think to check:1) Refer the AIMP\Plugins\aimp_sacd\2) Open the aimp_sacd.ini3) Set the PCMSampleFloat to 14) Save and restart the appWill it solve the issue? If not - try to change PCMSampleRate to 176400. Let me know about your results.
I wasn't read correctly and set a both suggestion
What else ? You can agree we can say problems is fixed What i forget Artem ?
