I believe that the JPG format is quite sufficient for the covers, PNG is much bigger. It shouldn't convert format without asking user and copied/original format should be kept.
Is it possible to increase the compression factor of the PNG format?
The difference in size is not great, but you can save some disk space.
It depends what quality is set for saving jpg. I just tested some covers and if set 95 quality value (original quality) and saved many times (10), there is no visual difference (no noise or color change). Only the size of the file has decreased (once), but without losing quality. Besides, who needs transparency in covers...
Yes, but probably with visible loss of quality.You can save a lot of disk space (comparing to png) using jpg (set to 95 quality value).
