both skins behave similair, but m5 greys out, becomes unclickable, crashes.roundabout after 2 hours.
before release candidate 2 or 3 betas before errors and crashes appeared.
I'm using aimp betas for years now, but it looks like that i have to use the regular version soon.did the leak file not showing any errors?
i use scrobbling on last fm, and 25% of transparency.
here is profile folder
May be a suggestion for the future:ability to change internal font size (dificult to read on very big screens, context menues and so on.)
Sorry about not able to write in russian letter (neither language) Privjet y Spasiba ( i hope thats right)!
Leak was in scrobbler plugin (what why debug version of player show nothing) in scrobbler's progress bar that shown in track information window only.
Build is here: https://disk.yandex.ru/d/oA6oyaGRa_73MgLeak was in scrobbler plugin (what why debug version of player show nothing) in scrobbler's progress bar that shown in track information window only.Thanks for helping!Refer to app settings \ interface \ scaling factorYep, almost correct (in transliteration it will be "privet i spasibo").Thanks again for helping to find this issue. I hope new build will works fine.
Same issue is also present in the skin editor when saving the project
i refer to change internal font AND size, not scaling, because scaling changes everything
