AIMP v5.30
easiy (may be automatically) would download a cover?
Topic: Add on or such to quickly / easiy (may be automatically) would download a cover? (Read 1063 times)
March 24, 2024, 23:27:53 »
Biff
Карма: +4/-0
Newest stable portable Aimp - Windows 11 unstable
Is there an add on or such that quickly / easiy (may be automatically) / with one or two clicks or so would download a cover (in good quality with proper resolution, so it doesn't look pixelated when displayed in Aimp) for the song just playing / the album?
Re: Add on or such to quickly / easiy (may be automatically) would download a cover?
March 25, 2024, 22:06:13 »
sveakul
Карма: +75/-0
Add Album Art Downloader (
https://sourceforge.net/projects/album-art/
) as a right-click selection in the "OpenWith" AIMP plugin. You can adjust the options to only get art of specified sizes from specified sites You will get shown what the results are and then pick/save the cover you want where you want. The only limitation is it won't save directly into a metadata tag.
March 26, 2024, 09:38:58 »
Biff
Карма: +4/-0
Many thanks for the link.
So then it looks like this:
And I have to - after clicking the item in the context menu - while playing any album add the fields "Artist" and "Album manually?
Or is there a way to do that automatically? And to save a cover or more in the album folder automatically?
Last Edit: March 26, 2024, 10:20:35 by Biff
March 27, 2024, 19:52:32 »
sveakul
Карма: +75/-0
It will automatically search on the file metadata without having to manually add Artist/Album; you can set some options in the GUI like in the shot below. If you were expert in the OpenWith "Params" options, which unfortunately I am not, you could add all kinds of auto-acting command line options to it (see the Help/Command Line Reference).
I was able to add many in the Mp3tag application's "tools" settings for AAD to work with it there:
/ar "%artist%" /al "%album%" /p "%_folderpath%%artist% - %album%.%%extension%%" /t f,u /mn 500 /mx 3000 /o a- /ac
But I haven't been able to "translate" that into what works for OpenWith!
April 03, 2024, 00:23:15 »
Biff
Карма: +4/-0
OK, thank you for the screenshot!
Unfortunately I am the opposite of an expert. But thank you for the Mp3tag, will use it as well (in Mp3tag).
