Just do that app requests.
Which App? I close the window with the hint by tapping on the cross in it.
why wasn't it placed on the home page for direct access?
Refer to the "About" dialog of the app, and check the "enable logging" option. Restart the app. Now, reproduce an issue and send the log file to me. Please, report to me a approximate time when issue was happened.
it seems like the app was previously killed by OSTurn off the battery saving to prevernt Aimp from closing while its playing in background (when is off or while other apps are using)
iBasso DX160, Android 8.1:The message "Background playbackit seems like the app was previously killed by OSTurn off the battery saving to prevernt Aimp from closing while its playing in background (when is off or while other apps are using)"no longer occurs since installing version 4.05.1398, good job. This means I can still close AIMP by tapping the exit cross without it remaining in memory.
have updated to 4.05.1398 but i get always the same warning , is there a way to disable it in the aimp option and not in the android phone ?
No, because in this case it may lead to playlists corruption
killed and it has never corrupted the playlsit in 1 year
you are lucky
ok ,but could be added a easy button to close the application ?just because enter always in the menu and tap exit it's not handyis there a gesture ?
hoped that newer versions would also stop this strange behavior.
@drugoI had always hoped that newer versions would also stop this strange behavior. Actually, I haven't changed the operation of AIMP for Android and the Android settings are still the same as when I had the same problems. I stop playing the music, shrink the window, wait for the playback path icon, usually headphones, to disappear and exit AIMP by clicking the cross in the window. I'm currently using version AIMP 4.10.1422, but I didn't have any problems with previous versions after 4.05.1398.
I think that user MUST know that app was abnormally terminated, because I'm tired to answer the emails about losing songs in playlists
Application may works incorrectly on devices based on MIUI firmware
