Background playback (6) it seems like the app was previously killed by OSTurn off the battery saving to prevernt Aimp from closing while its playing in background (when is off or while other apps are using)
Why you kill the app instead of close it?
is there a way to remove these warning?
Does the app in playing state when you kill it?
[qHiyes it does happen only when amip is playing and i kill itand i restart aimp i got this messagein aimp_4.02.1368 it does happen , and resume playing music after i kill it and restart aimpthanks
but often close aimp android it's hard to close it
but it's so hard to add an option to skip this warning in the preferences
I had already criticized this behavior because I don't see the point behind it (https://www.aimp.ru/forum/index.php?topic=71794.msg440265#msg440265). For a pure audio player without a telephone function and where there is no other open application, such a message makes no sense. For my device, AIMP is of the opinion that activating battery optimization can cause problems. I would also be in favor of version 4.05. The monitoring introduced can be switched off.
can you switch off and disable the banner i get it?can you tell me how?
There is no other app open. I start AIMP normally from the interface and after AIMP loads, before I tap play, this notice appears. I have to click away from this notice, then I start playing. AIMP is neither terminated during this process nor are any other processes observed. The music also plays normally. As already said, this only happens from version 4.05 and is just annoying.
