I can do an experimental project with what can be done with the skin engine possibilities but it will be more like an imitation.
Doar pentru distracție, dar nimic mai mult. [/citat]AJ. let's say it's good. But the skin editor should add (continue wave after the second). That would work.Like at 1:25 - the wave is over (former album)
How it works: https://drive.google.com/file/d/1733OhbfUMzn3FnOqOByVLhNj2sqzGpPt/view?usp=drivesdk
but it would also work automatically
Is full screen waveform (album replacement) good?
It's not supported by the skin engine.It looks pretty interesting, but not user-friendly.
but in the skin editor do you have milliseconds (eg 0:00.000)
You can see milliseconds only in the «information about the track» window. It's not supported for the main screen.
aaaah, thanks for the info.
What do you think of MEZZO 2 player?
N-am auzit niciodată de asta. Nu are nimic special în designul său. [/citat]1. what I said with the waveform (from left to right) (manual) - it has2. the album moves (if you select from the setting - UI)
