AIMP for Android v4.00
[+] [2524] [x64] AIMP: Cannot change device parameters on Sound Output
Topic: [+] [2524] [x64] AIMP: Cannot change device parameters on Sound Output (Read 4891 times)
October 30, 2023, 09:08:44 »
AndreyP
Also tested on stable; same issue
Seems to have locked me into certain settings and is forcing me to use 7.1 Surround instead of stereo, which is causing some problems considering I use headphones and it errors out (will include a screenie of the error as the last attachment too to be sure, but I'm almost certain it's because my headphones are stereo on windows)
Am I doing something wrong? How do I get the other options to appear instead of just forced 7.1 Surround?
Last Edit: October 30, 2023, 09:29:31 by Artem
Re: [2524] [x64] AIMP: Cannot change device parameters on Sound Output
October 30, 2023, 09:29:26 »
Супермен
Карма: +2930/-56
In WASAPI case, all parameters are defined on OS's side. Click the "..." button to invoke system settings applet
Re: [+] [2524] [x64] AIMP: Cannot change device parameters on Sound Output
October 30, 2023, 09:56:05 »
AndreyP
Guessed so, but the weird thing is I have the system settings for the headphone in stereo mode but it doesn't change on AIMP's side, even after a system restart
attached is a pic of the headphone config on windows (it is the default realtek driver device)
October 30, 2023, 13:27:39 »
digi340
Same problem on me.See this :
https://www.aimp.ru/forum/index.php?topic=71613.0
October 30, 2023, 14:03:48 »
Супермен
Карма: +2930/-56
No, it does not
October 31, 2023, 03:15:05 »
AndreyP
Still unsure on what to do, other audio options are only exclusive modes and pretending I have a 7.1 surround setup glitches some other apps, and I am sure I was able to change the setting on an earlier version last year
so sorry for bothering but idk what to do even though it's marked as solved, I loved using aimp and I'm so sad getting back to it that I can't use it without glitching my audio settings into 7.1
Edit: fixed by reinstalling audio drivers twice, sorry
Last Edit: October 31, 2023, 19:06:57 by AndreyP
