It impossible. Database stores only file records, folders generates automatically based on file paths
Database synchronizes with file system according settings
No, it impossible. Fetching the data from file system take to much time. So what why explorer plug-in displays content of current folder only (without sub folders)What reason to see empty folders in view? What you will do with that?
You already have that plugin called "Explorer View" but there are no options to View Thumbnails or otherwise "View" the files while using Explorer View
Explorer View is just a demo from SDK. So what why it so simple.
